new computer
- Re: new computer
new computer
29-11-2009 3:34 PM
I am trying to get acces to the internet on a new computer. It recognises the existence of my plus net wireless signal but asks for a network security key. I ve never been asked this on my other computer and wonder what I need to do to get access with my second computer.
2 REPLIES 2
Re: new computer
29-11-2009 3:44 PM
Assuming you're using a PlusNet supplied router and you haven't changed the security key from the default then check the instructions here
http://www.plus.net/support/broadband/hardware/t585v7new.shtml
Section 3 Connecting to your computer.
Hope that helps
dick:green Link fixed.
Hope that helps
Re: new computer
29-11-2009 11:02 PM
Specifically:
"Use the WPA-PSK key shown on the bottom of the router. It's 10 characters long and the letters are CAPITALISED."
You may not remeber doing this when you set up your original computer but you must have done if it connects wirelessly.
