netgear wg 111v2
specific
netgear wg 111v2
having a clear out,and come across netgear usb wg111v2 date on box 2005,i installed drivers of the web,but when i plug it in( netgear device not detected)is it because i am running vista and this device is only for xp hence date on box 2005?
Fixes: 113
Re: netgear wg 111v2
Did you install the vista drivers from here ?
According to that it should work ok.
Will Moderate For Thanks
specific
thanks adiewoo,
                                up and running,great stuff!  thanks again.
specific
now that i am wireless,laptop and main pc,should i connect the pc  cable to the router, say once a week,in case of updates etc,etc?thanks.
VileReynard
Seasoned Pro
Fixes: 9
Windows requires updates every few days.
Routers (which are connected to the internet, anyway) are unlikely to ever require an update!
