netgear wg 111v2
- Re: netgear wg 111v2
netgear wg 111v2
05-12-2009 1:54 PM
having a clear out,and come across netgear usb wg111v2 date on box 2005,i installed drivers of the web,but when i plug it in( netgear device not detected)is it because i am running vista and this device is only for xp hence date on box 2005?
4 REPLIES 4
05-12-2009 2:36 PM
Did you install the vista drivers from here ?
According to that it should work ok.
05-12-2009 3:29 PM
thanks adiewoo,
up and running,great stuff! thanks again.
05-12-2009 5:30 PM
now that i am wireless,laptop and main pc,should i connect the pc cable to the router, say once a week,in case of updates etc,etc?thanks.
05-12-2009 8:28 PM
Windows requires updates every few days.
Routers (which are connected to the internet, anyway) are unlikely to ever require an update!
