netbook with WiFi and phone Dongle
pierre_pierre
I have a netbook running XP SP3 and using Firefox and Thunderbird. a 3 Mobile Dongle when away from home but Wifi at home.
Two users SWMBO and me.
No trouble on SWMBO set up, but on mine (Only one install into her admin set up) the 3 Dongle insist on trying to dial up even thou the dongle is not plugged into the netbook, while doing so it stops the WiFi.
I have been all through the set ups I can find, but no sign of an auto dial button - any clues?
Re: netbook with WiFi and phone Dongle
In Internet Explorer tools/internet options /connections change the setting to either never dial or never dial when network connection is presant
Fixes: 61
This http://support.microsoft.com/?kbid=316530 might help explain it...
Quote from: pierre_pierre
Has someone mutilated their EEEpc ?
Fixes: 61
Yes , shame on you Pierre, retreating indoors behind those Windows!!
pierre_pierre
fear not friends, I still have the trusted Eeepc with Linux, but got the Wife a Medium with XP, its hard for us pensioner with no expences you know, But I am not as bad as Jim, that is the second time recently talking about IE explorer when I am using Firefox, I think the problem might be to do with adim restriction, the catalog on SWMBO was read only, that lessened the problem, but not completely., Just tried what Jim said, although I dont use IE, will have to try and grab it tomorrow when we go out the the Local NHS Depot
pierre_pierre
seems ok at the moment, just done a test
is that fast enough for a mobile dongle Crazy
