my webspace access
- my webspace access
Re: my webspace access
29-07-2009 12:11 AM
Thank you Jelv for your detailed response and thanks also Pierre-Pierre for the listing layout.
I decided to erase the oldforgegallery entry and concentrate on getting wlt001.plus.com sorted out .To this end I deleted all files and directories below htdocs in a bid to get rid of the index-space- ,htm file because it only showed when accessing the site by clicking on this link
http://www.wlt001.plus.com/
when viewed in Fireftp none of the web pages had the space in the file name . I,m totally baffled .
Having erased all the previous uploads I then found it impossible to upload the files from the local directory I cannot fathom out where I,m going wrong.
I log on using my password,
the site comes up in the right hand window
I select the files using Ctrl Rt mouse click in the local directory
and click on the upload arrow
Nothing . but a horizontal bar scrolls at the bottom Rt. of the Fireftp screen indicating some process happening
29-07-2009 11:20 AM
- Netscape Composer
- Notepad
- Dreamweaver
Make a folder on your computer cald My WebSite in it crate the folders that are going to make up part of your site, for eggzampul "images" for all your images, wen naming files keep them in Lower Case do not put the in Upper Case, and do not have spaces in the file name, if you must have a space in the file name do it like this: palls_logo.gif or palls-logo.gif or page_1.html or page-1.html
I hope this helps
03-08-2009 5:51 PM
03-08-2009 7:11 PM
19-08-2009 4:26 PM
There should be an index.html in the htdocs/oldforgegallery. This will be accessed when you go to http://www.oldforgegallery.co.uk/ It will also be accessed when you go to http://www.wlt001.plus.com/oldforgegallery
You can have a different index.html in http://www.wlt001.plus.com
Don't forget that within html files, links and images with relative paths are relative to the directory where the html file lives.
19-08-2009 5:15 PM
You links to the galleries on the left are not working, you have an incorrect relative address.
19-08-2009 7:52 PM
another easy to use ftp prog is FTP Commander.... but I found Filezilla to be the easiest to get on with, especially if you need to just delete a file and upload another from your "my computer".... just drag and drop it onto the folder on the server side.
04-09-2009 3:30 AM
Sorry I havn't replied sooner ,been working on a CB400N and I wanted to ride it while the rain is still warm <grn>
I have started to revamp my web pages by reverse engineering them to teach myself html as I go along I have managed to get the opening page
looking good , the second page and the link forward and back working but have come unstuck with one image on the third page and I cant see the syntax error ,yet. When I have all the pages and the links between them working on my PC .I will come back here and check out the uploading naming ,metatags and so forth.
Thanks again for your guidance, as "Arny "says " I will return."
WILT
04-09-2009 6:06 AM
Quote from: WILT ....but have come unstuck with one image on the third page and I cant see the syntax error...
The one that often catches me out is the rogue space. The other thing to remember is that the file structure / names are case sensitive when you upload your website. This as caught me out a few times in when I uploaded a fully working website from my PC.
10-09-2009 7:56 PM
I think my Webspace now has a clean bill of health I have an index.html page . with links and reverse links to 4 other pages containing the content and all the links work so How do I get these pages to show on google if someone types in oldforgegallery.co.uk ? and going on from that how do I insert relevant Meta tags into the page (pages ) as deemed necessary for the web crawlers to find me?
WILT
10-09-2009 9:41 PM
if you want to check it out, try it yourself, and see what happens, you can also type in mine, nemosphotography.co.uk and compare the type of results that come up
incidentally, the http url above returns a 404 error.... page not found.... so I suspect you still have not got the index.html in the htdocs folder.
OR... (just a thought.... you may have index.html but you may be needing index.htm (or vice versa! !)
12-09-2009 1:36 AM
I,m still flapping around here ,I cant get the last piece of the jig saw in place.I now have the pages and links between them all working properly Ive even sorted out the rudimentary META tags but I cant seem to get www._oldforgegallery.co.uk to point to the pages on the site I have put oldforgegallery .co.uk into the domain box but after that I,m lost .I cant get the link to work. can someone talk me through the last bit !.
12-09-2009 10:28 AM
also if you can post up your page link HTML lines, maybe someone can spot what is going wrong
12-09-2009 10:57 AM
here is a schematic of whats there :-
[DIR] root ./
I
htdocs./
I
index.html
gallery1.html
gallery2.html
gallery3.html
[DIR] oldforgegallery.co.uk
[DIR] oldforge
[DIR] images
the 2 directories beginning oldforge are not relevant to the web pages and are not linked in any way at the moment .The site works perfectly if I type wlt001.plus.com into a web browser. I do not know how to get oldforgegallery.co .uk to access it instead or as well as.
WILT
12-09-2009 11:13 AM
Go to here https://www.plus.net/my.html?action=domainv2
Under the domain name there is a configure button - clicking gives you this - just replace the blanked out bit with the folder name. It doesn't need to be oldforgegallery.co.uk but could be anything you want
