my web space - error 530 login incorrect
- my web space - error 530 login incorrect
16-01-2009 8:21 AM
hi, every time i try and log into my web space i get this error? (530 login incorrect) im using my account log in and have checked it, i've also tried rebooting my router and the whole comp but still joy can anyone help?
2 REPLIES 2
Re: my web space - error 530 login incorrect
16-01-2009 2:24 PM
How are you logging in are you using FTP if so which one. You should login with aniworld and your password. Depending on your account you may have to login via a plusnet ip soif you were doing it from another account it may not work
16-01-2009 6:08 PM
If you are trying to login to your ccgi webspace, first it needs to be activated via the member centre and then you get a new login just for ccgi use via mail.
If you are logging into your homepages webspace then what program are you using and what domain are you connecting to?
