ms dos cd
slanjavah
ms dos cd
Hi hope some can help. I wish to re format hard drive on laptop. cd rom is the boot disc. How do i create a ms dos bootable cd
Slanjavah
may the force be with you
gswindale
Re: ms dos cd
you really don't want an MS-DOS CD these days (IIRC it only came on floppies).
Do you not have the original Windows installation media? As this is normally a bootable CD and will be needed to reinstall Windows. (Assuming you're using Windows).  Similarly most Linux Install CDs are bootable.
dusty_bin
Re: ms dos cd
I tend tp concur with Geoff.  The installation discs usually allow you to delete/create partitions and format the HDD as part of the installation process.
That said, if you really want to make a bootable CD, in Nero  there is a 'help' entry for "Making bootable CDs".  Probably there is similar guidance with other CD writing S/W.
slanjavah
Re: ms dos cd
Thanks for that folks will see if I can get my original xp to reinstall
holdtight
Re: ms dos cd
As an aside talking about making bootable CD`s etc there`s everything you could need at Bootdisk.com
