moved to full fibre and need help setting up voip
mikedundas
Hi, Please keep it simple as I am really not a very Tech person.  I have just moved to full fibre and have managed to keep my land line number with A&A.  My landline is now not working and i need to set up the VOIP but what do i need to do.  A&A advised we purchased an ATA adapter Grandstream HT8xx ATAIPv6 to use with our normal phones.
Can anyone help me set this up please.  Where do I plug everything and do i need to change any settings on the Hub 2?
I would really appreciate any help you can give me please.
2 REPLIES 2
Fixes: 579
Re: moved to full fibre and need help setting up voip
@mikedundas There's some information on the A & A knowledge base here https://support.aa.net.uk/VoIP_Phones_-_Grandstream_HT8xx
although you will need to ignore the bits about IPV6 as Plusnet dont support it yet.
In terms of connections, you connect the HT8xx to a LAN port on the Hub 2 with an ethernet cable and you connect your phones to the FXS port on the HT8xx.
I dont use an HtT8xx myself but there are people on here who do, and hopefully can provide more complete information
Have you read the A&A help pages to do with that device ?
A&A : VoIP Phones - Grandstream HT8xx
A&A : VoIP Firewall
A&A : VoIP Security
Note that the A&A instructions mention IPv6 - which your Plusnet connection won't do unless you have a 6in4 tunnel configured, but your Grandstream should work fine on your IPv4 connection
I can't help you with the Hub 2 details - as I've never used a Plusnet router.
