mcafee
baccini
mcafee
Hi ive installed plusnet mcafee on my w7 desktop, when I change user accounts its not available there is a shortcut on the desktop which does nothing some help would be appreciated thanks
shalom2010
Re: mcafee
Hi
Not sure about this, but I would think you need to uninstall & reinstall with full Admin rights. If you right click on the .exe install program you select 'Properties' & select the 'Compatibility' tab and tick 'Change settings for all users'. Maybe also visit the 'Security' tab
and see if Privileges are correct.
baccini
Re: mcafee
Thanks for your reply never encountered this problem before im going to do a bit more research before I do anything if it becomes to much of a problem its out with mcafee and in with avast or m.s.e cheers
Re: mcafee
Yep, I soon ditched the McAfee in favour of Avast.
Call me 'w23'
shalom2010
Re: mcafee
You're welcome w23. I'm trying out Norton 360. Seems so far very good (on a 30 day free trail + currently half price at £30 for a year).
baccini
Re: mcafee
hi again I was advised by plusnet to reinstall and look for an option to select for all users which there wasn't so it back to square one.
