lpg and avi in same slideshow?
- lpg and avi in same slideshow?
05-09-2008 5:03 PM
Last hols I took mainly jpg stills and a few avi video clips. Is it possible to mix the two types in a single sideshow? Is there any trick or trap to be aware of, if it can be done?
3 REPLIES 3
Re: lpg and avi in same slideshow?
05-09-2008 5:12 PM
that depends on which program you use to make the slide show, as some stop after a video, others go straight on, just going off to look at some I use
05-09-2008 5:19 PM
A slideshow is a series of stills. So you could make a video file with stills in it but you can't make a slideshow with video in it.
Yes, you can mix the two in a video. Every video editing software I have used has the facility to drop in image files. What's really cool is that you can add video effects to these jpegs. So you can pan across a photo or zoom in to a defined area on a defined path.
What software have you got?
05-09-2008 5:37 PM
FWIW I am using Nero 6 Reloaded
