loss of signal
dennisb66
loss of signal
I use a Netgear DG834G v3 wireless router which connects my desktop PC and laptop. Over the past few days i have been losing the signal strength,keeps fluctuating between v good and zero.When it drops the signal light on the router keeps flashing.  Is this a sign that i need a new router.
Fixes: 10
Re: loss of signal
Have you tried using a different channel?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Re: loss of signal
Somebody else has started using wifi close by you and causing interference  ? - have you looked at what signals are around.
dennisb66
Re: loss of signal
On channel 11 at moment jelv,will try another channel.
Quote from: mal0z
not sure how i could do that malOz
Dick:Green Quote fixed Mod:end
Re: loss of signal
What OS are you on - ?
hover over the wifi icon at bottom right of screen and there should be something like - "Look for networks "  ( sorry I don't have wifi on this desktop ) and laptop is in office.
dennisb66
Re: loss of signal
Ah,now i understand malOz .Do not appear to have any other networks in range at moment. I have changed to channel 12 and all seems ok at moment.Will see how it goes.Thanks to you both for your input. Wink
pierre_pierre
Re: loss of signal
if some one else was on 11 you want to be at least 3channels away
Re: loss of signal
Do any routers monitor performance and change channel if they get poor quality signal - i.e intermod/ blocking / high BER from adjacent channels etc
davidj66
Re: loss of signal
Vista doesn't actually show the channel number of other in range wireless access points.
pierre_pierre
Re: loss of signal
I havnt got Vista, but on my two systems, you right click for the details, near where I am on Chan 1 at 100% is
53& on 11
another 53% on 11
21% on 5
and 43% on 3
dennisb66
Re: loss of signal
Have tried various channels but signal is same on all,drops very low.    Pierre how do you find the % rating,  My browser is firefox if thats relevant.
pierre_pierre
Re: loss of signal
Nothing to do with the browser, I did that on a Netbook andd Linux, on the find local WiFi to log onto, Just going to fire up my XP to see that one
The XP just gave a bar graph with no numbers
shot below  is  in my local Freeport Shopping Centre
dennisb66
Re: loss of signal
Interesting,thanks Pierrie
