logitech quickcam pro 3000 driver prob
- logitech quickcam pro 3000 driver prob
11-01-2008 4:55 PM
does any one know of a driver that will work with vista.
logitech web site says the webcam will never work with vista.
one person on a froum said they used the driver off the cd and it worked with windows messenger but the software that came with the cam did not.
i havent got the cd. downloaded the xp software from logitech but does not seem to have the driver.
does any one know a good site to get drivers from.
2 REPLIES 2
Re: logitech quickcam pro 3000 driver prob
11-01-2008 11:08 PM
all the vista drivers are on
http://www.radarsync.com/vista/index.php?vendor=Logitech
Cant see your model but theres lots to try,
Vista will accept XP drivers if they are signed
15-01-2008 12:36 PM
solved this driver problem jus logitech trying to make me buy a new cam of them.
They wrote the new driver to not work with vista but found a guy that knew how to change a few of the pid inputs.
any one else got this problem check this page out pretty simple to follow.
http://groups.google.com/group/alt.comp.periphs.webcam/msg/217f9beaa4a99239?
vista is a pain in the backside without companys like logitech makeing it worse.
