linking across two routers
- linking across two routers
23-06-2009 5:21 PM
My son has ensconced himself in the shed, and wants to use the wifi, but it's a bit too far down the garden. I am using the new D Link router supplied by PN, but have my old Belkin sitting in a cupboard.
Can I set up the Belkin to effectively extend the range of the D Link?
Re: linking across two routers
23-06-2009 7:17 PM
Quote Can I set up the Belkin to effectively extend the range of the D Link?
If you mean wirelessly using WDS, then I doubt it!
If you could run a CAT5 cable between the two routers then yes.
23-06-2009 7:36 PM
Is there any other way to boost the signal from the DLInk?
23-06-2009 7:48 PM
23-06-2009 7:59 PM
Quote Is there any other way to boost the signal from the DLInk?
Does it have an external aerial connector ? Sometimes a decent aerial can give a reasonable improvement...
23-06-2009 8:14 PM
23-06-2009 8:17 PM
Have a look at http://www.broadbandbuyer.co.uk/default_ShopGroup.asp?ShopGroupID=61
