linking across two routers
hulls
I'm sure this has been discussed before, but here goes.
My son has ensconced himself in the shed, and wants to use the wifi, but it's a bit too far down the garden.  I am using the new D Link router supplied by PN, but have my old Belkin sitting in a cupboard.
Can I set up the Belkin to effectively extend the range of the D Link?  Undecided
6 REPLIES 6
Fixes: 393
Re: linking across two routers
If you mean wirelessly using WDS, then I doubt it!
If you could run a CAT5 cable between the two routers then yes.
hulls
That's a pity  Embarrassed  I'd hoped to be able to link across them.  Running a cable to the shed is possible, but the point was to avoid that.  I suppose I could run a cable to the Belkin and place it as close as possible (so that I don't have to run a cable outside).
Is there any other way to boost the signal from the DLInk?
Fixes: 1,483
If you have power in the shed have you thought about powerline adapters?
Fixes: 393
Does it have an external aerial connector ?  Sometimes a decent aerial can give a reasonable improvement...
hulls
Yes - the shed has power, how do the power line adapters work?
Fixes: 1,483
you plug one in near the router and one in the shed and the power cables are used as a network.
Have a look at http://www.broadbandbuyer.co.uk/default_ShopGroup.asp?ShopGroupID=61
