left shift key not working
nevglufc
I have a dell dimension with media centre and a multimedia keyboard and in the last week or so the left shift key is not working.
I have tried a different keyboard and it it the same.
The left one works fine but I use the left one all the time.
is it  a setting that i have changed in error?
it is really annoying when typing emails as i keep getting ' instead of @
29 REPLIES 29
Denzil
Re: left shift key not working
The other keyboard you tried - do you know for sure that one is OK? New ones are dirt cheap, so it is worth trying one.
samuria
Why do you not get @ are you using the wrong keyboard ie US not UK?  Try the keyboard in safe mode ie press F8 on startup and select safemode doe it work ok then?
Peter_Vaughan
A UK keyboard has ' as the standard (non-shifted character) and @ when you hold the shift key down. The OP's problem is the shift key does not work so he always gets '
nevglufc
if i hold the right shift key down for approx 10 seconds then the left shift key works as normal for a while, I get the @ and then it stops working again '
Strat
Fixes: 565
Quote from: nevglufc
.....which turns on Filterkeys Huh
nevglufc
which means what? apologies for not knowing Huh
Pendragon
Have a look here;
http://www.microsoft.com/enable/training/windowsxp/filterkeys.aspx
Might help a bit, regards, P
nevglufc
no change
thanks
Strat
Fixes: 565
Sorry nevglufc, it was just a long shot but it did seem to have some connection as in...
Keep us posted if you find a solution. Smiley
Edit: Have you tried removing and re detecting the keyboard in Device Manager.
nevglufc
I did a system restore to a month ago and also deleted keyboard out from device manager. Unplugged keyboard and put back in to another USB port, it connected fine and all is well again.@
THANKS
Nev Smiley
God
I did manage to recreate this briefly by turning on and changing some 'sticky key' options. maybe it was turned on in error (pressing shift 5 times).
nevglufc
Same thing has happened again but after unpluggeing keyboard and put back in to another USB port, it connected fine and no change ' instead on a @
Sticky keys are off so completely confused, maybe a system rebuild, but a bit drastic
Any help appreciated
pierre_pierre
thats one of the differences between a UK  and US keyboard, have you got the £ (English) or # (American over the Shift 3
shutter
Fixes: 64
Isn`t this something to do with the keyboard settings?  either English (english) or English (usa) or possibly English (european)  (if there is a european version)..... Huh
