laptop batteries
- Re: laptop batteries
laptop batteries
08-08-2009 10:03 AM
Hi
Is it still the case that these batteries need to be "worked"? What I mean is that they work better if they're charged and then discharged on a regular basis?
5 REPLIES 5
08-08-2009 12:03 PM
Yes.
Also it is said, if you are working on mains, take the battery out
08-08-2009 9:53 PM
Apples recommendations for getting the best out of their batteries here http://www.apple.com/uk/batteries/notebooks.html
08-08-2009 10:17 PM
Thanks. I suspect he uses it plugged in most of the time, so I'll recommend using it on battery at least once a week, and then recharging.
09-08-2009 9:25 PM
and discharging it fully, then recharging it fully.
10-08-2009 11:04 PM
Yes
