laptop batteries
hulls
laptop batteries
Hi
Is it still the case that these batteries need to be "worked"?  What I mean is that they work better if they're charged and then discharged on a regular basis?
5 REPLIES 5
pierre_pierre
Re: laptop batteries
Yes.
Also it is said, if you are working on mains, take the battery out
Fixes: 1,483
Apples recommendations for getting the best out of their batteries here http://www.apple.com/uk/batteries/notebooks.html
hulls
Thanks.  I suspect he uses it plugged in most of the time, so I'll recommend using it on battery at least once a week, and then recharging.
KenA
and discharging it fully, then recharging it fully.
hulls
Yes  Roll_eyes
