javascript to replace inverted commas
chenks76
All Star
Fixes: 12
i have a little script that strips out any characters from a text variable.
Function Encode(DirtyText)
	Dim CleanText
	Cleantext = Server.HtmlEncode(DirtyText)
	CleanText = Replace(CleanText, "'", "''")
	CleanText = Replace(CleanText, vbCrLf, "<br>")
	Encode = CleanText
End Function
i want it to be able to strip out inverted commas too, ", and replace it with something else>
however
CleanText = Replace(CleanText, """, ".")
 doesn't work as it doesn't like """.
so does anyone know how to do this?
the end result is used as follows.
newvariable = Encode(cstr(request.form("oldvariable")))
12 REPLIES 12
jelv
Fixes: 10
Re: javascript to replace inverted commas
Try
CleanText = Replace(CleanText, '"', ".")
or
CleanText = Replace(CleanText, "\"", ".")
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
chenks76
All Star
Fixes: 12
both of those produce syntax errors
Try this :
cleanText = dirtyText.replace(/['"]+/g, '.')
chenks76
All Star
Fixes: 12
nope
Microsoft VBScript compilation error '800a03ea'
Syntax error
/includes/functions.asp, line 44
SpendLessTime
Fixes: 86
Try using
 Chr(34)
as the string to be replaced
VBScript so it may need escaping so put a \ in front of the forward slashes. i.e.
(\/['"]+\/g, '.')
Edit:- Just so you know (assuming this works) this will replace all occurrences of a double quote with a .
chenks76
All Star
Fixes: 12
still nope
Syntax error
/staffportal/includes/functions.asp, line 44
cleanText = dirtyText.replace(\/['"]+\/g, '.')
@chenks76 - No that's fair enough as that's not how regular expressions work in VB land according to my search (but would have for JavaScript). Have a look here it should give you a pointer as to what you need to do, if you want to continue with it.
MJN
Fixes: 5
The double-quote " is a special character in VBScript and so to use it literally (i.e. without special meaning; just as a character) use two consecutive double-quotes instead. Thus:
CleanText = Replace(CleanText, """", ".")
(Caveat: I don't know this from first hand experience of VBScript, just a cursory Internet search)
jelv
Fixes: 10
Sad
It would have helped if your original post had said you were trying to use VBscript and not Javascript!
MJN
Fixes: 5
Did you get anywhere with this @chenks76?
chenks76
All Star
Fixes: 12
haven't looked at it again yet.
tied up with other stuff right now.
