javascript and html drop-down menu
- javascript and html drop-down menu
23-05-2017 3:58 PM
i've got 2 drop-down menus on a webpage
the first drop-down is a set of options.
the second drop-down displays a range of options based on what the first drop-down selection is.
this is done via a set of "lookup" files trigged by a bit a javascript
$(function() { $("#menu1").change(function() { $("#menu2").load("lookupfiles/" + $(this).val() + ".txt"); }); });
this all works fine if the values of menu1 are numbers (ie 1,2,3,4 etc etc).
they correspond to 1.txt, 2.txt etc etc
all good so far.
it also works OK if the value is text and has no spaces in it.
example "selectedoption" successfully loads the options from "selectedoption.txt".
however, if the value of menu1 is some text with a space in it.. ie "selected option", the script doesn't seem to be able to supply the set of options from the lookup file called "selected option.txt".
now, due to integration issues with an existing system, then menu options have to stay as they are (with text and spaces etc).
is it possible to get this working with the spaces in the options?
Re: javascript and html drop-down menu
23-05-2017 4:02 PM
@chenks76 - I would suspect you'll have to encode the spaces using %20.
23-05-2017 4:11 PM - edited 23-05-2017 4:13 PM
i suspected as much, but therein lies the problem.
as the values for the first menu are pulled in from the existing system i cannot change them.
so i guess i would need to encode the space after it exists in the menu and before it hits the javascript
the orginal drop-down is populated thus
<select name="root" id="root"> <% WHILE (NOT root.EOF) %> <option value="<%=root.Fields("callmd3_listitem").value %>">
</option>
<% root.movenext()
Wend %>
</select>
23-05-2017 4:19 PM
For Classic ASP try:
<select name="root" id="root"> <% WHILE (NOT root.EOF) %> <option value="<%=Server.HTMLEncode(root.Fields("callmd3_listitem").value) %>">
</option>
<% root.movenext()
Wend %>
</select>
23-05-2017 4:22 PM - edited 23-05-2017 4:22 PM
just as you typed that i worked out to solve it in javascript too (i think)
$(function() { $("#menu1").change(function() { $("#menu2").load("lookupfiles/" + encodeURIComponent($(this).val().trim()) + ".txt"); }); });
