itunes 8
- itunes 8
- « Previous
- 1
- 2
- Next »
Re: itunes 8
19-09-2008 11:31 AM
@craigyoung, I've not actually got an iPod Touch myself. I've got a humble 3rd gen model (which I refer to as my legacy iPod!) and a 5th gen model. The only way to get a Genius playlist onto these is to create one in iTunes and manually copy it across AFAIK.
Re: itunes 8
19-09-2008 12:36 PM
Yes, but my parrot joke was still good though....
I have a second or third gen which is permanently on charge in the gym as the battery went after on a year or two. I carry a 5th Gen but I have a permanent fuzzy line running across the screen which is fairly annoying. Quite a lot of money for things which don't last all that well.
Still - better than carrying a cassette walkman and have to rewind it using a pencil because you didn't want to waste the batteries.
Re: itunes 8
19-09-2008 12:47 PM
didnt you use both sides and turn it over? saved all that fafing around
Re: itunes 8
19-09-2008 12:53 PM
Yes, but the sides were never the same length so you always had a bit of tapes to get through. Though I used to be so particular about my music, that I would cut and splice cassettes down to the exact length they needs to be. What a saddo...
Re: itunes 8
19-09-2008 12:55 PM
do you mean to say you also open up your memory "cards" and clip bits off the corner?
Re: itunes 8
19-09-2008 3:00 PM
Indeed.
And I really regret sawing the ends of my plasma screen the day I was watching an old 4:3 movie.
Re: itunes 8
19-09-2008 3:05 PM
But is does not annoy you with those black edges, have you tried araldite when you have a new movie?
- « Previous
- 1
- 2
- Next »
