is this possible
- is this possible
is this possible
13-02-2010 2:26 PM
I Have a standard Thompsons modem supplied by Plusnet and my desk top computer is wired into this as I am not really a fan of wireless networking, however I have several relatives who visit and own laptops and would find it useful to use my broadband connection to access the internet. Is there any way this can be done or can the modem only be used for one or the other but not for both at the same time ?
If this cannot be done what is the simplest and cheapest way to set up wireless broadband but still retain my wired connection ?
Thanks.
Thanks.
We are born into history and history is born into us.
3 REPLIES 3
Re: is this possible
13-02-2010 2:32 PM
Both at the same time with no problems
15-02-2010 8:19 PM
Easy to do.... get them to switch on laptop, and let them "find" your wireless connection..... tell them the "password" (key) and they should connect no problem. !...
My wife and I have laptop each, and both wireless connect, plus we have had three other "visitors" on the connection at the same time... (all wireless, but as Jim says... no problem wired and wireless together)
15-02-2010 8:46 PM
Just one thing to add - the Thomson has a facility to turn on / off the wireless with the button on the front - hold it for about 3 second to toggle on or off.
That way your wireless is not radiating when not in use.
You might need to upgrade the firmware to do this
see the guide here:
http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
see the guide here:
