ipod touch
- Re: ipod touch
ipod touch
03-03-2009 12:46 PM
Re: ipod touch
03-03-2009 12:49 PM
I sincerely hope the "password" isn't your wireless password! That would be pretty risky if that were the case.
You need to use the password that you set up for your wireless connection. If you have a Thomson Router, it should be written on the underneath of the router.
Re: ipod touch
03-03-2009 12:52 PM
Re: ipod touch
03-03-2009 3:41 PM
Re: ipod touch
03-03-2009 3:45 PM
Re: ipod touch
03-03-2009 3:47 PM
Re: ipod touch
03-03-2009 3:51 PM
Re: ipod touch
03-03-2009 3:56 PM
Re: ipod touch
03-03-2009 3:57 PM
Quote from: newb sorry under the box there is a wireless pin no is this anything
Your best bet is to give our Call Centre a ring and they'll be able to talk you through the whole thing.
You need to tell your ipod touch which network to join (this is normally called an SSID) and to use the right password.
Re: ipod touch
04-03-2009 4:09 PM
