iphone and plusnet mail
- Re: iphone and plusnet mail
10-02-2008 12:04 AM
I have an iPhone and have successfully sync'd it with my mac computer, and everything works fine via my wifi connection. Also everything works except mail via GPRS and EDGE. Now I know that my account SMTP is set for plusnet (relay.plus.net). Out of range of a plusnet connection I can receive mail but I'm unable to send mail via GPRS and EDGE (obviously).
now I've set up a new account with all the same info except the smtp bit which I believe is smtp.o2.co.uk but no joy with that. Is there a surefire way to send email using 'Mail' (rather than webmail) without the tears?
INFO:
I am only using one email address on my iPhone so it should be pretty straight forward but I think I'm missing a trick somewhere.
Any clues anyone?
10-02-2008 2:26 AM
10-02-2008 8:25 AM
Quote from: Bob Use SMTP auth. ......
Sorry, being a bit dim this morning Bob. Do you mean replace relay.plus.net with SMTP auth ? on the only account on the iphone?
10-02-2008 8:47 AM
10-02-2008 9:49 AM
10-02-2008 10:09 AM
Quote from: ruslyn This should help:
http://community.plus.net/forum/index.php/topic,60436.msg491483.html#msg491483
Good link, will try it when I have a minute.
Particularly good tip if you screw up settings on the iphone (Like I did last night) just plug in to sync computer and it sorts it all out for you again!
[edit]
Just a thought. would this be the same if using my laptop on a bt openzone hotspot? coz I've been changing 'relay.plus.net' to 'smtp.btopenzone.com' every time.
10-02-2008 10:24 AM
Authenticated SMTP can be used on non-plusnet networks. In fact you can also use it on PNs network so once set, you don't need to change it moving to/from PN.
10-02-2008 10:28 AM
You learn something new all the time
10-02-2008 10:30 AM
10-02-2008 1:08 PM
Cheers all, now off to watch the rugby!! C'mon England.
