ip address
mac
ip address
just a quick one
on the general tab it says use the following ip address but it is blank.
and on the use the following dns server address thats also blank should these field be filled in?Huh
many thanks
James
Re: ip address
Hi Mac,
I reckon that by those entries being blank, they'll just get obtained automatically, which is pretty normal.
mac
Re: ip address
yes your right
many thanks
