ip address
- Re: ip address
ip address
13-01-2009 3:48 PM
just a quick one
on the general tab it says use the following ip address but it is blank.
and on the use the following dns server address thats also blank should these field be filled in?
many thanks
many thanks
2 REPLIES 2
Re: ip address
13-01-2009 3:50 PM
Hi Mac,
I reckon that by those entries being blank, they'll just get obtained automatically, which is pretty normal.
Re: ip address
13-01-2009 4:01 PM
yes your right
many thanks
many thanks
