ip address look ups location results.
scootie
i normaly use http://whatismyipaddress.com/ for doing look ups of ip addresses but it wouldnt work for a microsoft ip address i was looking up but as normal it checked my ip address on loading as normal told me i lived on the moors of harogate way of the mark.
but when i checked this site http://www.ip-adress.com/ to do the microsoft ip lookup i noticed that it had my loaction nearly spot on by 10 miles in fact i had lived in the town it gave for 20 years of my live.
how come this site nearly got it right?
17 REPLIES 17
Strat
Fixes: 565
Re: ip address look ups location results.
Both addresses show me as London and I'm quite close to you.
Denzil
For me, http://whatismyipaddress.com/ doesn't give a map, and just says London. http://www.ip-adress.com/ is a bit more specific, and says Wokingham. Presumably these reflect server locations rather than user locations?
Oldjim
Resting Legend
Fixes: 63
This is where it thinks I am - a bit far from deepest Dorset  Grin
Strat
Fixes: 565
I believe it's offering a recommendation Jim Smiley
scootie
oldjim does this one give the same location http://www.ip-adress.com/
techguy
These are usually based on either who the IP is registered to which is usually drawn from http://www.ripe.net or some use the info and add in a calculation for ping response etc to roughly guess where you might be I think.
For example, the ones you have linked to think I'm in Winchester which is not far from where my ISP is based but if I use http://www.ip2location.com it indicates London which is where their equipment is (Telehouse in Docklands like some of Plusnet's and other ISPs)
Maybe PN have an edge router at a DC in Dorset perhaps oldjim?
Fixes: 1,483
Both show me slap bang in the middle of the Yorkshire dales.
Would be nice to be there but a couple of hundred miles out..
hulls
http://whatismyipaddress.com/ ; shows me as in Slough (I think it usually just feels like it!) www.ip-adress.com/ is much closer and just shows North London(ish)
pierre_pierre
hadnt loked closely at you Pic John, now I know.  Not far from Hulls, IP is Sheffield, the other in Mid Sussex, diagonally across London
Oldjim
Resting Legend
Fixes: 63
Quote from: ASBO
That gives Plusnet in London
Strat
Fixes: 565
I've now moved from London to High Wycombe. Substantial improvement Smiley
I'll keep trying as one never knows Wink
James
Have you ever been to High Wycombe?
I wouldn't refer to it as an improvement!
Strat
Fixes: 565
Well it sounds nice Undecided
techguy
And Winchester is definitely an improvement on Milton Keynes
Well errr I hope.
