intel or AMD
- intel or AMD
intel or AMD
25-04-2014 3:36 PM
Re: intel or AMD
25-04-2014 4:05 PM
Not sure how true that is now but for my next build I may move over to Intel as there is better support for my video editing software.
Forum Moderator and Customer
Re: intel or AMD
25-04-2014 4:08 PM
That and the fact that AMD were changing sockets far too frequently at that time
Re: intel or AMD
25-04-2014 4:48 PM
but it depends on what you intend to use it for , overall intell is the better CPU but at a higher cost
Re: intel or AMD
25-04-2014 4:58 PM
I think there's a lot of hype about processors nowadays with many users paying for i5 performance they don't really need.
I'm sure AMD processors around the same price are also 'surprisingly good' if you don't need top-end gaming performance or similar.
Re: intel or AMD
25-04-2014 4:59 PM
Re: intel or AMD
25-04-2014 5:39 PM
Intel have more recently caught up in terms of price vs performance and more importantly these days power consumption - every wasted watt consumed on a 24/7 basis will cost you around £1 a year in energy - not all is wasted as you may be wanting to warm your room up etc but the newer Intel processors knock spots off the AMD for overall value when considered in the long term savings.
Re: intel or AMD
25-04-2014 8:33 PM
