installing earlier versions of Firefox on Mac
- installing earlier versions of Firefox on Mac
06-05-2014 6:09 PM
Been having weird issues since last update to v28.
Decided I want to try going back to 27 instead of forward to 29. (Curiosity.)
Just checking if anyone has done this. Can I just overwrite v28 already installed or is best to remove old one first?
Only got couple of add-ons, can easy grab those again if necessary.
Re: installing earlier versions of Firefox on Mac
06-05-2014 7:01 PM
06-05-2014 7:50 PM
That was easy.
But didn't solve the problems (that seemed to arise since v28). So back to the drawing-board...
Having to use Safari to look at iPlayer (or any BBC site), and few others.
06-05-2014 9:47 PM
24.5.0 I think is the current one.
Linky here.
06-05-2014 10:38 PM
I'll try it tomorrow.
Still be able to use Ghostery, etc., do you think? (I tried disabling add-ons earlier so it was not them causing the weirdness.)
edit - I have to go get this stuff via Safari. Can't get on Mozilla at all due to this problem
07-05-2014 2:00 AM
07-05-2014 6:26 PM
ESR worked
Somewhat quicker, too. (Speeded onto this forum in a flash.) Check it out people!
So I can watch iPlayer again without having to fire-up Safari or some other.
Noticed a (paid-for) Firefox add-on while I was there.
https://addons.mozilla.org/en-US/firefox/addon/cck/
Says, among other things, you can disable about:config. Being a bit ignorant I'm wondering what would be the advantage of that?
Thanks, that was brilliant. I'll buy you a virtual drink
07-05-2014 7:03 PM
That add-on would be useful for organisations who want to lock down the functions of a Firefox install. Not really useful for home users though, unless used in a parental situation, possibly.
07-05-2014 10:41 PM
_________/
\ /__--z
| {~~|ß
| †ea | /∫
| | /ƒ
__{---------------}__
I'd be fascinated to know what's missing from the ESR version (that I'm not missing at all at the moment!).
And very pleased I don't have to go delving into the config file!
11-05-2014 2:02 AM
Now cannot access iPlayer on Firefox of any kind, nor Safari. Even tried Dooble.
I notice that pesky 212.56.73.* IP cropping up on the firewall log again everytime I try iPlayer. What's up with that or why it might be causing problems I don't know, maybe the link is not working. Apparently its Google - why I'm unable to access BBC sites at all if there's a Google link issue is also a mystery, and an annoyance.
Tonight I'm fed up with internet, and the people who run it. I have a few words but I'll spare the mods the trouble of censoring them!
12-05-2014 6:40 PM
12-05-2014 7:32 PM
At stage now where, as you say, its a bit of a mystery.
Yes, do have something to work on now. - Previously there was just no response at all. Now I'm getting pages that look like they're missing their stylesheets.
So, iPlayer used to get Akamai IPs - 23.61* 23.62*, etc. That's stopped and its now 212.56.73.* (PN's weirdy google-cache thing).
Could this mean some of the content is getting shunted round Google servers instead of Akamai?
And that there's something going wrong with it?
Not knowledgable about these things so just guessing...
12-05-2014 7:50 PM
12-05-2014 8:34 PM
Just went through everything on the router pages, I can't find anything about that - apart from dynamic DNS, which is disabled.
It'll be whatever the default set-up was? I've never tinkered with it.
13-05-2014 3:07 AM
Go back to the Network list and click the Apply button.
After that's been set try iPlayer out to see if it works correctly, just to check completely try on different browsers.
To remove those DNS server settings just select them and click the minus button, quite simple really.
