in car computing with laptop - a query
- Re: in car computing with laptop - a query
27-09-2010 4:16 PM
27-09-2010 4:24 PM
if you say your laptop works on 19v DC
then to connect it to a 12v car supply you need
a 12V DC to 19V DC voltage converter
you can see them for sale here http://www.powerstream.com/19v-index.htm
27-09-2010 4:27 PM
unless you car is stationary and switched off then its not a good idea
27-09-2010 4:37 PM
What a stupid thing to say.... about a car driver connecting a laptop whilst driving...... that would constitute.... "driving without due care".... in the same way as using a mobile phone....
(as a matter of interest.... did I mention connecting my (any) laptop whilst driving ?)
27-09-2010 5:26 PM
Quote I'd never advice a car driver to connect a laptop inside a car while driving
please read what I did say
thank-you
27-09-2010 5:31 PM
will run directly from the 12v cig socket.....
not using an inverter to make 250v ac, then plug in your laptop power supply to bring it down to 19v !...
(also implying dc to dc converter)
please read what I said.
27-09-2010 5:39 PM
it does not involve a 240volt or any other converter
its just steps up 12v to 19v by electronic design means
but no matter my postings are correct
27-09-2010 6:18 PM
27-09-2010 6:23 PM
27-09-2010 6:45 PM
27-09-2010 10:26 PM
and do you know how they step up from 12v to 19v?
27-09-2010 10:31 PM
27-09-2010 10:52 PM
27-09-2010 10:59 PM
Quote from: itsme DC voltages cannot be stepped up without converting to AC.
Oh yes they can.
e.g. http://en.wikipedia.org/wiki/Charge_pump
27-09-2010 11:04 PM
As a designer I use tried to avoid DC to DC converters as these can emit high frequencies and is a consideration for EMC.
