iPod Touch
acr
Re: iPod Touch
You do not need to re-sync your iPod. On your iPod go to Settings > WiFi and touch the name of your network. You will then be asked for your Password. Enter your WEP password and touch 'Join'. You only need to enter it once. It will then reconnect automatically.
Hawks
Re: iPod Touch
Thanks very much indeed ruslyn and MisterW.  I am up and running now.  What a relief ! Roll_eyes
Fixes: 396
Re: iPod Touch
Glad we could help...
Hawks
Re: iPod Touch
Thanks again.  I'm really greatful. Take good care.
