iPlayer beta site
bobpullen
Fixes: 330
iPlayer beta site
Anyone that uses the BBC iPlayer may be interested to hear that they've launched a beta version of the site.
5 REPLIES 5
HairyMcbiker
All Star
Fixes: 21
Re: iPlayer beta site
Want's to install Adobe Air - Don't think so mate!  Crazy
artificer
don't  need it.  works ok without.  it's going to take a bit of getting used to.
scootie
i just watched the hint an tips vid and after that zipped round the new features and liked what i saw
HairyMcbiker
All Star
Fixes: 21
If you want to stream it doesn't need it but if you want to storer it it does. No bit of Adobe bloatware is going on my system. Sad
newthing
Cheesy
Clicked Yes to Install Air?
"click" Black screen, machine powed off.
thats the most spectacular crash I've seen in a while-
straight to OFF. no messing about with blue screens
error messagaes whatever.
T.
