iPad to PC transfer?
jmd
A friend has some photos/information on her iPad that I would like on my laptop which uses W7.  Other than attaching it to emails which would take for ever, can you transfer stuff easily from iPad to PC?
I just wonder if using a pen drive would be difficult due to different systems?
[if this query is in wrong thread sorry!]
Re: iPad to PC transfer?
Can you transfer the items using Bluetooth or Wifi, I think for the Wifi options you need to find a client for the iPad which supports 'WebDAV'.
3Mb FTTC
quick goggle http://www.knowyourmobile.com/appleiphone/ipad/ipaduserguides/457971/how_to_share_files_between_an_i...
edit: bah  didn't read guide enough
Note: at present the file sharing feature is only supported by Apple Mac computers running Mac OS 10.5.8 or later.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 25
Quote from: jmdlp
I don't think iPads have a USB port, so nowhere to plug it in!
Fixes: 62
Would one of these work -  ipad dock connector to usb cable
I cant say with 100% certainty, but I dont think the iPad will allow that without being jailbroken.
3Mb FTTC
jmd
Oh well, think we may to do it in small bits by email! Sad
Fixes: 61
It would appear there's an app for that Grin http://itunes.apple.com/us/app/photo-transfer-app/id365152940?mt=8
or if you want a general purpose file transfer there's an app for that as well  Grin http://itunes.apple.com/gb/app/filebrowser-access-files-on/id364738545?mt=8
VileReynard
All Star
Fixes: 11
Can an ipad do FTP?
Not really, but WebDAV is close, its uses simple POST/GET commands from HTML.
Go to the AppStore, and type 'WebDAV client' there are a few free Apps listed which will do what you want.
3Mb FTTC
snozboz
Or use Dropbox https://www.dropbox.com/
edit: Ooops, sorry I ended up "bumping" this thread back to the top.  I read it from "Unread Posts" and didn't look at the date of the original post before replying.  Roll eyes  Embarrassed
