iPad resolution
- iPad resolution
iPad resolution
20-12-2020 1:59 PM
Is it possible to change the screen resolution on a iPad Air (3rd generation) ?
Looking at answers on the internet it does not seem possible....the question relates to another post in a different section of the forum on feedback tab.
Re: iPad resolution
20-12-2020 2:04 PM
@gleneagles It certainly isn't possible on a 'normal' iPad, and I don't think it will be on the Air - these things seem to be 'fixed' on Apples portable devices. What size screen do you have, out of interest?
Re: iPad resolution
20-12-2020 2:12 PM
As you said you can't change them as they are indeed fixed. So this means that the HTML / CSS used to display this side tab needs updating to take these various screen sizes into consideration.
A screen capture from your device @gleneagles would be of benefit to anyone in Plusnet capable of doing a fix. For my iPad Air 2 I touch the home (fingerprint) button then pressed top (power) button.
Re: iPad resolution
20-12-2020 2:17 PM
@gleneagles , @Mook I checked my iPad earlier - see my response in the other post - and that tab doesn't obscure anything - it just annoys me.
Re: iPad resolution
20-12-2020 2:21 PM
Not for you @jab1 but as I understand it is does for @gleneagles
Re: iPad resolution
20-12-2020 2:23 PM - edited 20-12-2020 2:26 PM
I understand that, @Mook , but I can't think of a logical explanation.😖
EdiT: @gleneagles can you not scroll away from that tab and then hit reply?
Re: iPad resolution
20-12-2020 5:48 PM
Fair enough I can scroll past it but as you move up or down on to another page it tends to scroll up with the page.
Its just a nuisance rather than a major issue
I think the size of my screen is 9.7 or thereabouts.
Re: iPad resolution
20-12-2020 5:51 PM
Would changing the browser zoom level make a difference?
Re: iPad resolution
20-12-2020 6:02 PM
Same as mine then, but that tab doesn't go so far left.
