iPad/iPhone mail
- iPad/iPhone mail
iPad/iPhone mail
23-06-2018 10:46 AM
When I opened my iPad this morning for the first time for several months, I found in my Mail Inbox (apple generic app) there were over 200 emails in it, none of which I want to keep having already been dealt with through my Laptop Thunderbird account.
Is there a way to delete all mails with one key stroke (in Inbox and Trash folders), or must they be laboriously deleted one at a time?
Re: iPad/iPhone mail
23-06-2018 9:19 PM
If your mailbox is setup at POP3 you could always remove the mailbox completely through Settings, then add it back again. This process should delete your mail permanently.
If your mailbox is setup as IMAP, you may be best off going into the webmail of whichever mail provider you’re using as I imagine you’d be able to mass delete from there.
Hope this helps.
24-06-2018 5:31 AM
Thank's Gandalf.
Found a way of deleting quicker if not actually en-mass, In Trash, tap Edit and tap the small circle that appears alongside each mail header, this adds a blue tick, you can tap as few or as many as you like scrolling down, then tap Delete (bottom right of the column) and those selected will delete. This at least becomes a one tap operation rather than the individual swipe and confirm (if you're set that way) of single delete.
Has the advantage of giving the opportunity of not tapping a mail you want to keep, or changing your mind and un-ticking if required.
