iPad Air - internet connection
Floribunda
I have an iPad air and up until last Monday it worked fine.  Since then I have been unable to connect to the internet wirelessly (no other way with the iPad).  I have a really lousy broadband speed here and there are times of the day when an internet connection is not available.  However.... usually at some time of the day I can connect.  I have been trying since Monday to no avail.  So my question is, how do I find out if this is a Plusnet problem or whether my iPad has developed a problem?  I don't have a simcard for the iPad.
2 REPLIES 2
chenks76
All Star
Fixes: 12
Re: iPad Air - internet connection
only way you can test is if you connect another device to your network and test it.
shutter
Fixes: 65
Take your Ipad to Starbucks/ mcdonalds....  or Wyevale Garden centre ,.... or othere "free" wifi centre..... see if it connects to them....
