iPAD
iPAD
03-03-2011 4:59 PM
Is it possible to do crosswords and download things from an Ipad ?
Are there any particular snags in using an ipad.
Any advice would be appreciated
Re: iPAD
03-03-2011 5:02 PM
Re: iPAD
03-03-2011 5:09 PM
I have a Kindle which I am impressed with but it's just B&W and the screen size might be a bit small for reading a paper but the actual print is excellent, so something that's easy on the eye to read and light weight like the kindle but with the other things mentioned earlier (if such a thing exists)
Re: iPAD
08-03-2011 6:57 PM
I've had a shot of the iPAD and they are quite slick and very easy to use but they do have their limitations and a high price tag.
Re: iPAD
08-03-2011 7:43 PM
Re: iPAD
08-03-2011 8:00 PM
Re: iPAD
08-03-2011 10:16 PM
I would avoid Apple though, no flash support if you want to go visit sites that use Flash a lot (excluding Youtube/iPlayer as they have apps apprently) so I'd go with Android or wait for Meego which is another Linux OS (Intel/Nokia), but really, the initial cost is quite horrific for half decent models, though you can get a subsidy if you're willing to pay per month and enter a 12 month contract with a phone company.
Re: iPAD
08-03-2011 10:21 PM
Quote from: David Google are going to release Honeycomb soon
...which the soon to be released Galaxy 10.1 is running. I read that Samsung held back on it's release once the iPad2 was announced.
Re: iPAD
08-03-2011 10:50 PM
It drives me mad if someone points at something on my PC screen and leaves their greasy fingerprint on it.
Even *most* ATM's don't use touch screens.
Re: iPAD
09-03-2011 4:18 PM
http://en.wikipedia.org/wiki/Lipophobicity
Re: iPAD
09-03-2011 4:36 PM
Re: iPAD
09-03-2011 6:46 PM
