Following on from my purchase of the Yamaha P115 keyboard I am thinking of getting a cheap second-hand iPad 2 (minimum specs) to add further functionality like extra voices, and so on. The cheapest I can find a connector is over 50 squid and I have spent a fair amount already and that does seem rather expensive. The connector is as below:
But I am wondering if I am correct in thinking the following two connectors would do the job at a fraction of the price Both together at less that £6:
Also, I gather that if I do get an iPad 2 it can be updraged to iOS 6 (minimum) or 7. It looks easy to do from Google searches but are there and issues/pitfalls I should be aware of?
Edit: links to the above connectors:
i-UX1
Female Type A to Male Type B
Genuine Apple 30-Pin to USB Cable
Forum Moderator and Customer
