hub one - modem mode
roberkwild
hi all,
just want to know if the hub one router can be turned into a modem only like the virgin media routers can so you can plug in your own router
cheers
rob
4 REPLIES 4
Fixes: 1,482
Re: hub one - modem mode
short answer is no Smiley
roberkwild
ok well thats that out the window
i will just need to buy another VDSL modem and connect it to my router, what VDSL modem would you recommend
what is the point of the ethernet WAN port then
Mustrum
Fixes: 76
The longer answer is to use your other router as a wireless access point, or change the IP address range on one of the routers so they don't clash.
The wan port on the hub one is if you want to use an external modem.
roberkwild
great thanks guys
