hub one and another router for vpn
iangilf
hi is it possible to add a router to my existing hub one to access vpn server for my network if so which one is best and how is it done or would i need to buy a standalone modem/router to gain this feature?
thanks
7 REPLIES 7
Fixes: 1,474
Re: hub one and another router for vpn
You could add a raspberry pi that’s connected to the vpn and install something like squid to route your traffic.
I’ve done this and it works fine.
iangilf
hi i have a raspberry pi 2 but no idea how to do it and would it route all traffic threw all pcs and wifi devices?
Fixes: 1,474
so you don't want it as an additional access point you want to route all traffic from all devices through a VPN?
30FTTC06
Fixes: 4
I would go with an rpi 3 minimum which tbh will be good for around 50mbps, other than that I would go for a Netgear D7800  R7800 with custom firmware. you need plenty of grunt when phushing everything through vpn.
iangilf
hi that netgears a bit too pricey for what i would use it for are there any other cheaper models about ?
30FTTC06
Fixes: 4
Sorry that was a typo with the router above, R7800 or an R7000 will do the trick.
Why bother messing around with something that just isn't going to do a proper job ?
iangilf
hi so its ok to add another router to the hub one yes ?Huh
