htaccess rewrites
Fixes: 6
htaccess rewrites
Hi
I've got a quick question about rewrites in htaccess files.  This is about an external web host and not any of Plusnets servers.  htaccess is meant to be fully supported, so if it's possible to do what I want, the it should work!
I've recently redesigned 2 websites that I work on, with both the originals being pretty well used.  Come launch time for each of the new sites, I'll want to make the old site unavailable and the new site available very quickly.  On each site the live sites are at www.example.com and the new sites are at www.example.com/newsite/. ; Is it possible, using rewites for when a user goes to www.example.com/directory1/Somepage.php for them to actually to see the file from www.example.com/newsite/directory1/Somepage.php without them seeing a change in the address bar?
Does any of that make sense!?!
Phil
1 REPLY
pierre_pierre
Re: htaccess rewrites
Makes perfect sense to me and have seen it done even today, sorry though dont know how
