how to switch wifi off/on online at night
twocvbloke
Re: how to switch wifi off/on online at night
Quote from: 7up
Seriously.. why would you want one of those?
Cos I like them, and what I like matters to me... Cool
(Oh, and I liked them long before moving here, so the TV transmitter's got nothing to do with it)
PeterLoftus
Fixes: 5
Quote from: twocvbloke
Quote from: 7up
When the kids were young we had Citroen Dyanes. I had company cars but we preferred to go for a run in the Dyanes. Convertible and you could take the seats out for a picnic. Easy to work on as well, a complicated a a lawnmower  Cool
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
7up
Fixes: 17
Quote from: AlaricAdair
Visible light does you no harm: http://www.jamesbondwiki.com/page/Goldfinger's+Laser+Room+Pics+%26+Clips
Er you do realise it wasn't real right?
nanotm
yeah but this one is real https://www.youtube.com/watch?v=E3YCACZQ72Q
and its not exactly news that lasers cut stuff up is it medics have been using micro lasers for surgical procedures for many years /
7up
Fixes: 17
Ah yeah... but the bond one is not real  Tongue
He wasn't talking about real lasers was he...
Besides.. we all know that a STRONG enough light can be harmful - thats how solar power stations work that use an array of mirrors focussed on a central tower work. There was one designed that also works as a laser using the energy from the sun but i've never managed to find it online but saw a programme about it once.
But my point it this... your living room light bulb still isn't as dangerous as wifi.
twocvbloke
Quote from: 7up
I broke one once and got a shock off it when I went to remove it (yeah, forgot to turn it off), had I been up a ladder I could have fallen off and split my head open on something, so they can be more dangerous than wifi routers... Grin
7up
Fixes: 17
Ok.. you got me.. i hadn't thought of that! Cheesy
twocvbloke
Gotta remember Elven Safe Tea, thinking up all kinds of accidents that could happen because of less smart people that prove evolution's a thing... Grin
ReedRichards
Seasoned Pro
Fixes: 25
Quote from: Hobo
There is usually a button or switch on the router to turn just the Wi-Fi on or off.
The problem here is that the intensity if the wifi radiation will follow an inverse square law with distance from the transmitter.  So if you are worried about this, the last thing you should do is put your hand (or any other body part) close to the router - which you would have to do to switch it off or turn-off the wifi.
7up
Fixes: 17
Richards is right... what you really need is a computer (such as a pi) hooked up via a short ethernet cable with a little program that will log in via http and disable / enable your wifi as at specified times.
Don't ask me how, I know very little about linux. If it was a windows box (Pi size) I could do it without hassle but not using linux.
twocvbloke
Or, you could just have your router scheduled to turn the wifi off, as most decent routers have a built in scheduling system that can do such things... Cool
nanotm
that's ok 7up, most routers run on some version of nix anyway Tongue
Anotherone
Champion
Fixes: 21
Or you could just log into it from any of your connected devices and turn it off with the relevant command. You would of course have to log in with an ethernet connected device to turn it on - or go and press the button for the required duration and then run Tongue
VileReynard
Fixes: 20
Or you could plug your router into a timeswitch.
Beware the EM radiation from timeswitches though. Cheesy Cheesy Cheesy
7up
Fixes: 17
Which would be peanuts compared to a radio transmitter - which wifi uses.
Ridicule it all you want but how many times have people laughed at dangers they cannot see only to be had by it later?
