home plug advice please
- home plug advice please
15-03-2010 11:09 AM
hopefully the guys an girls that i remember buying and using these are still about the forum to offer some feedback as am thinking of getting a couple to hook my spare xbox up staris to use a media extender, i was going to get a wireless adapter but for the price you pay for microsoft one it would be better to have somthing i can use on stuff other than the xbox.
so about the 50 quid mark for a pair of the cheap end of homeplugs, any one used the basic models?
http://www.solwise.co.uk/net-powerline-pl-85pe-mk2.htm
3 REPLIES 3
Re: home plug advice please
15-03-2010 1:35 PM
yup! I've got two sets operational in two different locations. They do a splendid job
For just a bit more (About £56 IIRC) you can have the option of a Wireless endpoint as well as slightly faster speeds.
Go for it- is my opinion.
M
M
19-03-2010 9:16 PM
I'll second that. We've got our PS3 hooked up using Netgear HDX101s and it works great. I picked them up second hand on eBay for around £50 the pair.
Bob
Bob
20-03-2010 3:43 PM
I have 2 rather cheap ones in the form of 4 port switches just because I wanted to try them. I wouldn't say I get anything close to the 85Mb through them but that is probably down to my mains wiring. Anyway they work really well for internet access.
My cousin has offices with several computers spread throughout a large old house converted to offices. He also uses the homeplugs without issue even for file sharing.
