home phone drops call on first ring
Fixes: 4
We had a strange problem last night with our phone while trying to call out, we noticed that the line just dropped as soon as the phone at the other end rang, tried 2 mobile networks o2 and virgin with the same result, phone rang once then dropped the call. So we tried ringing the home phone from a mobile which sorted the problem out. I would point my finger at soak up but our line is fine with no problems with the broadband anyway.
Filter ?
Re: home phone drops call on first ring
Hi 11110_110,
Something doesnt sound right either way. If you have another filter its worth trying it but if you notice it happening again, let us know so we can run some checks on the line.
