hangfire on AVG v9 update its buggy
- Re: hangfire on AVG v9 update its buggy
23-10-2009 2:44 PM
23-10-2009 2:48 PM
23-10-2009 4:53 PM
23-10-2009 5:00 PM
24-10-2009 7:35 AM
I have also been looking at Microsoft Security Essentials as a replacement for AVG and Defender. Anyone got any experience of this?
Bob
24-10-2009 1:00 PM
@bobboulby had the same defender was turned off by it
Still using Vista64, waiting for a month or 2 before I install Win7.
24-10-2009 2:03 PM
BUT.... not sure if it will get updates on viruses because of
this....
AVG Free edition 9.0 is now available
To stay protected you will have to upgrade your version
which is on the bottom of the AVG overview panel.....
24-10-2009 2:10 PM
Quote from: bobboulby Microsoft Security Essentials as a replacement for AVG and Defender. Anyone got any experience of this?
Yes, seems OK. Used it on a few systems (mine and other peoples).
Slight oddity in my new W7x64 install that one specific inbuilt security check flagged up that I had no AV despite MSE working fine. No warnings from the main monitoring though, so there's a minor bugette in the guts of W7 - surprise, surprise!
24-10-2009 2:49 PM
Hopefully AVG will keep the 8.5 signature updates coming for a while so I'll stick with my current set-up and decide what to do later.
Bob
02-11-2009 3:01 PM
02-11-2009 4:23 PM
in particular AVG 9 has a section here
http://forums.avg.com/gb-en/avg-free-forum?sec=theme&act=show&id=161
Scroll down a bit and you will see threads about it "freezing" etc....
hope that helps some of you....
02-11-2009 7:32 PM
Re:hangfire on AVG v9 update its buggy
03-11-2009 10:47 AM
17-11-2009 5:19 PM
Guess what I've just tried disabling and the problem seems to have gone away!
Edit: Drat spoke too soon - it's back again
17-11-2009 6:27 PM
