googlemail
duryard
googlemail
Hiya
Is it possible to have my googlemail account collect mail from my plusnet account?Huh
1 REPLY
Fixes: 247
Re: googlemail
Yes it is,
settings > account and import
set it up under check mail using pop3
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
