google hates me
- Re: google hates me
google hates me
09-04-2010 8:25 PM
any one else having google chuck the auto search terms box up in the left like below, its so getting on me thingymejigs as it dosent go away and have to keep shuting the tab down when it happens.
edit. this happens after ive done the search
7 REPLIES 7
Re: google hates me
09-04-2010 8:58 PM
Google hates you but not me....
(Googled with Konqueror on FreeBSD and Midori on Debian)
Re: google hates me
09-04-2010 9:20 PM
I am on straight Firefox and Win 7, no problem
Re: google hates me
09-04-2010 11:43 PM
Tried Vista and 7, IE8, Mozilla and Chrome. No problems here.
Re: google hates me
10-04-2010 12:22 AM
Firefox 3.5.9 & XP Home - no problem here Asbo. What have you done?
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
Re: google hates me
10-04-2010 9:41 AM
Is that the famous "google tool bar"...... and have you installed the famous " google search box" to your toolbar?
perhaps if you removed both, and stuck with the FF or IE toolbars, you would not have the problem..... also you will have a few more lines of viewing space on your screen.....!
Re: google hates me
10-04-2010 11:14 AM
left hand tool bar with the search results just appeared i think about a week or 2 ago.
ive not installed any google add ons and the GF no's not to install nothing with out my say so, so i thought this was just somthing google had auto added.
Re: google hates me
10-04-2010 11:24 AM
ok, seems to be the left hand bar options that throw this bug into action on vista ie8
i dont normaly use IE ive been using FF but the GF seems to think IE is better and when i muscle my way back on the living room machine IE seems to allways be open and i end up using it.
asbo searchs for the uninstall button
