google hates me
scootie
google hates me
any one else having google chuck the auto search terms box up in the left like below, its so getting on me thingymejigs as it dosent go away and have to keep shuting the tab down when it happens.
edit. this happens after ive done the search
7 REPLIES 7
Waldo
Re: google hates me
Google hates you but not me....
(Googled with Konqueror on FreeBSD and Midori on Debian)
pierre_pierre
Re: google hates me
I am on straight Firefox and Win 7, no problem
Addnan
Re: google hates me
Tried Vista and 7, IE8, Mozilla and Chrome. No problems here.
198kHz
Fixes: 41
Re: google hates me
Firefox 3.5.9 & XP Home - no problem here Asbo. What have you done?  Wink
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
shutter
Fixes: 65
Re: google hates me
Is that the famous "google tool bar"...... and have you installed the famous " google search box" to your toolbar?  Cheesy
perhaps if you removed both, and stuck with the FF or IE toolbars, you would not have the problem..... also you will have a few more lines of viewing space on your screen.....!
scootie
Re: google hates me
left hand tool bar with the search results just appeared i think about a week or 2 ago.
ive not installed any google add ons and the GF no's not to install nothing with out my say so, so i thought this was just somthing google had auto added.
scootie
Re: google hates me
ok, seems to be the left hand bar options that throw this bug into action on vista ie8
i dont normaly use IE ive been using FF but the GF seems to think IE is better and when i muscle my way back on the living room machine IE seems to allways be open and i end up using it.
asbo searchs for the uninstall button
