google crome.
owlguard
google crome.
Hi,ive downloaded crome web browser and it seems good after giving it a try and it being faster e.t.c.Does plusnet have any problems with me doing this and is google crome good,bad or what.
        regards ray.
Fixes: 19
Re: google crome.
Plusnet don't mind what web browser you use.  However there is some debate (see http://community.plus.net/forum/?topic=87243.msg724108 ) about whether Chrome uses more of your bandwidth allowance than other browsers.  I use Chrome and haven't noticed any problems.
owlguard
Re: google crome.
Hi Reed,thanks for the info,i will keep an eye out for the usage.Thanks for your time,its appreciated.regards ray.ps just got in,so only just seen your post to send thanks.
