front and rear jack, diffrent sim audio streams
scootie
ok am trying to get spotify playing out the rear jack and FF cbeebies website to play on the headphone jack at the same time, i have found the option in the realtek hd audio manager.
But how do i now tell each app to use which output jack?
Fixes: 19
Re: front and rear jack, diffrent sim audio streams
I know with Skype you can set the audio inputs and outputs but I suspect with many other programs you cannot.
Fixes: 15
I know you can do it in Linux, using PulseAudio manager, isn't there something similar available in windows land?
scootie
probably is and i will have a look tonight, just wanted to see if i could do it with out having to take up any HD space
