free dvd burner programmes
- Re: free dvd burner programmes
09-10-2009 3:37 PM
I` m looking tp download free dvd/cd burner software, does anyone have any experience of the many currently on offer ? Any no no`s ?
Help would be greatly appreciated.
CWS
CWS
8 REPLIES 8
09-10-2009 3:40 PM
if you only want to burn complete disks imgburn is excellent (it doesn't support leaving a disk open)
http://www.imgburn.com/index.php?act=news
09-10-2009 4:17 PM
Infrarecorder. The best I've found, bar none. Does everything Nero does, doesn't install music players/libraries/video players/wave editors/label makers that you don't want meaning the installer is less than 5mb. It's brilliant
http://infrarecorder.org/
09-10-2009 5:58 PM
Thanks for the prompt replies guys, some help & direction there.
CWS
CWS
11-10-2009 3:31 PM
Cheers for the link orbrey, been looking for a decent alternative to Nero. I use Nero at the moment but find it far to bloated for my needs
11-10-2009 7:39 PM
also check out cdburnerxp I have been using this for the past year without any problems and no adverts to bug you.
We are born into history and history is born into us.
17-10-2009 1:40 PM
Does cdburnerxp or Infrarecorder let you burn a .avi and .srt file together (.srt is for a subtitle file). Anything I've found on Google seems to be a complicated affair of downloading a lot of software to hard encode the film and subtitles, then export to another program, etc. I.m just looking for a quick solution that lets me add the two files to DVD quickly and then it does the rest, thanks.
17-10-2009 8:49 PM
DeVeDe (Windows & Linux) allows you to do this.
It's not quick for burning to CD/DVD as you need to perform a conversion from avi to DVD - which takes loads of resources.
17-10-2009 9:28 PM
Cheers for that, I'll have a look the now
The wait doesn't bother me, I'm used to waiting an hour odds for nero to convert lol
